Palm Centro Discuss Palm Centro Here
Old 08-09-2008, 04:02 PM   #1 (permalink)
Default Battery Overview on Palm Centro
Battery Overview - Palm Centro
Battery Specifications
  • Up to 210 Minutes "Talk Time"
  • Up to 300 Hours Stand by Time
Battery Basics
  • Do not use a battery that has not been approved by the manufacturer, as this may damage the phone and / or battery.
  • Battery life depends on the network, signal strength, temperature, features, and accessories used.
  • It is common for batteries to be warm from use or charging. If the battery becomes hot to the touch, it is recommended to replace the battery.
Tips for extending battery life
  • Avoid exposing the battery to extreme heat and cold.
  • For the first 3 charge cycles, fully charge the battery overnight and allow it to fully discharge before recharging (battery conditioning).
  • Charge and re-condition a battery after an extended idle period.
  • A lithium-ion battery may be damaged by extensive overcharging (continuously on a charger for more than 24 hours).
  • Keep your phone, batteries, and the contact terminals clean. The contacts can easily be cleaned with a pencil eraser.
  • Use the battery. If possible, avoid letting your battery sit idle for long periods of time.
  • Use only the phone options and accessories that you really need.
Battery overview on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 07:59 PM
Battery Overview on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:32 PM
Battery Overview on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 03:04 AM
LG Chocolate 3 Battery Overview admin_mvu LG Chocolate 3 0 07-14-2008 04:16 PM
Battery Overview on LG Decoy admin_mvu LG Decoy 0 06-17-2008 11:16 AM
