01-25-2010, 08:57 PM
How to Lock / Unlock Palm Pixi Plus
Phone Lock - Palm Pixi Plus
Enabling the phone lock
Disabling the phone lock
Changing the PIN
- From the Home screen, touch the launcher icon.
- Touch Screen & Lock.
If necessary, swipe horizontally or vertically to locate.
- From the Secure Unlock section, touch the secure unlock field then select the desired option.
- Off
- Simple PIN
- Enter the desired PIN then touch Done.
- Re-enter the PIN then touch Done.
- Password
- If presented, enter the PIN then touch Done.
- Enter the desired password.
- Select the confirm password field, re-enter the password then touch Done.
- If presented, selected a lock option from the dropdown menu.
- Screen turns off
- 30 seconds
- 1 minute
- 2 minutes
- 3 minutes
- From the Secure Unlock section, touch the lock icon.
- Touch Off.
- Enter the PIN / Password then touch Done.
Changing the PIN / Password
- From the Secure Unlock section, touch Change PIN / Change Password.
- Enter the PIN / password then touch Done.
- Enter the new PIN / password then touch Done.
- Re-enter the PIN / password then touch Done.
If re-entering the password, ensure the confirm password field is selected.
