Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Discontinued Samsung Phones > Samsung a930
Samsung a930 Discuss Samsung a930 Here.
Old 12-21-2007, 04:03 PM   #1 (permalink)
Default How to enable / disable the auto save messaging feature on Samsung SCH-a930
Enabling / disabling the Auto Save messaging feature - Samsung SCH-a930
  1. From the main screen, press the left soft key to choose Message.
  2. Press the left soft key to choose Settings.
  3. Select All Msg then press OK.
  4. Select Auto Save then press OK.
  5. Adjust settings as desired then press OK.
    • Select On to enable the auto save sent feature.
    • Select Off to disable the auto save sent feature.
    • Select Prompt to be asked if the message is to be saved.
How to enable / disable auto save messaging feature on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:46 PM
How to enable / disable auto save messaging feature on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:14 PM
How to enable / disable the auto save messaging feature on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 12:02 PM
How to enable / disable the auto save message feature on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:48 PM
How to enable / disable auto save message feature on Samsung Gleam (SCH-u700) admin_mvu Samsung Gleam 0 01-03-2008 05:51 PM
