Samsung a930 Discuss Samsung a930 Here.
Old 12-13-2006, 11:08 PM   #1 (permalink)
Default Send Ringtones to Samsung a930
1. Fix up your ringtone to be less than 300kb
2. Convert it to .wav (e.g. xilisoft)
3. Open the .wav in the windows Sound Recorder
4. Go to File > Properties > Convert now
- PCM
- 22.050 kHz, 16 bit, Mono - 43 kb/sec
- hit ok, ok again and file > save
5. Convert the .wav back to .mp3 (same prog)
6. Rename filename.mp3 to filename.mid.mp3 (if you have set the preference where you don't see the common extensions, then rename it to filename.mid)
7. Open up the file in winamp
8. Right click on it and go to "View File Info"
9. Check ID3v2 tag and fill in some info (title, artist, album, year and genre should do) and hit update
10. Open up your e-mail client
11. Email the filename.mid.mp3 to your phone as an attachement (phonenumber@vzwpix.com)
12. When your phone receives it (wait time may vary) go to options > save sound
13. Delete the .mid and hit OK and it should save fine
The key here is the ID3v2 tag
Old 12-26-2006, 04:26 AM   #2 (permalink)
Telegraph User
m1ssy is on a distinguished road
Default a990
- PCM
will this work for the a990?
m1ssy is offline   Reply With Quote
Old 12-27-2006, 01:51 PM   #3 (permalink)
I don't have a990 so I can't say for certain but it's worth a try.
Old 12-28-2006, 11:14 AM   #4 (permalink)
Stratman103 is on a distinguished road
THANK YOU! This is the only place on the web that I was able to find instructions on doing this that I was able to follow and that WORKED.
Stratman103 is offline   Reply With Quote
Old 12-28-2006, 11:30 AM   #5 (permalink)
Glad to hear that it worked for you.
Old 01-11-2007, 02:35 AM   #6 (permalink)
CorporalHawke is on a distinguished road
I don't have e-mail or texting on my phone. At least I don't think so. Is there some way to make my own ringtone for the a930 without having texting? Like with my memory card and a USB cable?
CorporalHawke is offline   Reply With Quote
Old 01-11-2007, 08:07 AM   #7 (permalink)
If you have Samsung a930, you have e-mail capability.
But, the better way is to use memory card and USB cable. (The e-mailing method is for people who don't have the USB cable or the memory card)
For USB cable, I think you need to use program like Bitpm to access your phone and you can put any wallpapers and/or ringtones in there.
Old 01-11-2007, 10:58 PM   #8 (permalink)
Ohh. Thanks! There was a delay in getting my phone to me, but I should get it in a week or so. In the mean time I have my choice between the e815 (Motorola) and some Samsung (my dad forgot the model number) that's about a year old.
Old 01-24-2007, 07:15 AM   #9 (permalink)
msbmt is on a distinguished road
Default does this really work on a930
Does this really work for the Samsung a930? Even though the MP3 capability is unavailable. Everything I tried always saves as a .qcp file, but I don't have the exact capabilities described above. I don't have a program to do all the suggested changes and just want to know if this works for sure before I buy a program.
Thanks
msbmt is offline   Reply With Quote
Old 04-02-2007, 06:07 AM   #10 (permalink)
ClwTL will become famous soon enough
if this approach doesn't work then try the new post using bitpim under tips section .
ClwTL is offline   Reply With Quote
How to create and send a FLIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:12 PM
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to create and send a PIX message on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 11:57 AM
How to create and send a PIX message on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:49 PM
How to create and send a FLIX message on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:35 PM
