Samsung Alias Discuss Samsung u740 Alias Here.
Old 09-20-2007, 12:06 PM   #1 (permalink)
r33tc0w is on a distinguished road
Default Micro SD Card
Just picked one up, 2gb. How do I need to format the folders on the sd_card so that the phone recognizes the paths?
r33tc0w is offline   Reply With Quote
Old 09-20-2007, 01:59 PM   #2 (permalink)
aztater's Avatar
aztater is on a distinguished road
Just put the card into your phone, your phone will format it. Then take it out and use on your computer to fill with everything you want. Then return to your phone. Should work like a charm.
aztater is offline   Reply With Quote
Old 11-28-2008, 03:09 PM   #3 (permalink)
drummer44 is on a distinguished road
do u have to have vcast to use an SD card
drummer44 is offline   Reply With Quote
Old 11-28-2008, 05:56 PM   #4 (permalink)
VCast has nothing to do with the SD card. It's for storing songs, pictures, videos, etc.
How to insert / remove a memory card on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:54 AM
Using The Micro SD Card Wizzer LG Dare 3 08-16-2008 09:23 PM
PC Card FAQ admin_mvu Wireless PC Cards 0 01-02-2008 09:55 PM
