Synchronizing Music - Samsung SCH-u740
Ensure that the correct VCAST Music software is installed before attempting to synchronize music. For additional information please refer to:
Installing VCAST Music Essentials Kit
Installing Music Essentials Manager- Connect the handset to the PC using the USB cable.
- Place the handset into synchronization mode.
The device must be open in rotated / landscape mode.- From the main screen, press OK to choose Menu.
- Select Get It Now then press OK.
- Select Music & Tones then press OK.
- Select Sync Music then press OK.
- Select the desired software application then follow the step-by-step instructions.
