Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Discontinued Samsung Phones > Samsung Convoy
Samsung Convoy Discuss Samsung Convoy (SCH-u640) Here
Old 12-22-2009, 12:28 AM   #1 (permalink)
Default How to Send picture message - Samsung Convoy (SCH-u640)
Take and send a new picture
Send a picture from device memory
  1. From the main screen, press the camera key (located above the Send key).
  2. Aim then press OK to choose TAKE.
  3. Press OK to choose SEND.
  4. Enter the 10-digit mobile phone number or email address then press OK.
  5. Enter text if desired.
  6. Add a Sound if desired.
    1. Select the Sound field then press the left soft key to choose Sounds.
    2. Record a new sound if desired.
      1. Select RECORD NEW then press OK.
      2. Press OK to choose REC.
      3. Press OK to choose STOP.
    3. Select the desired sound then press OK to choose SET.
  7. Add a Subject if desired.
  8. Add a Name Card if desired.
    1. Select the Name Card field then press the left soft key to choose Add.
    2. Select the desired option then press OK.
      • My Name Card
        • Select the desired number then press OK.
      • Contacts
        1. Select Contacts then press OK.
        2. Select the desired contact then press OK.
        3. Select the desired number then press OK.
  9. Press OK to choose SEND.
Send picture from device memory
  1. From the main screen, press OK to choose MENU.
  2. Select Media Center then press OK.
  3. Select Picture & Video then press OK.
  4. Select My Pictures then press OK.
  5. Select the desired picture then press the right soft key to choose Options.
  6. Select Send then press OK.
  7. Select Picture Message then press OK.
  8. Enter the 10-digit mobile phone number or email address then press OK.
  9. Enter text if desired.
  10. Add a Sound if desired.
  11. Add a Subject if desired.
  12. Add a Name Card if desired.
      • My Name Card
      • Contacts
  13. Press OK to choose SEND.
