01-03-2008, 06:00 PM
How to enable / disable auto save message feature on Samsung FlipShot (SCH-u900)
Enabling / disabling the Auto Save message feature - Samsung FlipShot (SCH-u900)- From the main screen, press the left soft key to choose Message.
- Select Auto Save Sent then press OK.
- Adjust settings as desired then press OK.
- Select On to enable the auto save sent feature.
- Select Off to disable the auto save sent feature.
- Select Prompt to be asked if the message is to be saved.
