Samsung FlipShot Discuss Samsung u900 "FlipShot" Here
Old 02-26-2008, 09:41 PM   #1 (permalink)
invwill is on a distinguished road
Default Ringtones on flipshot
Does anyone know how to add ringtones to the phone....I already have the usb cable and the drivers. Tried using bitpem but it didn't work. Can anyone help????
invwill is offline   Reply With Quote
Old 02-27-2008, 07:53 AM   #2 (permalink)
What do you mean by it didn't work?
Were you not able to see the phone from bitpim? Not able to put the files? Or the phone won't find the new ringtones?
Old 02-27-2008, 05:50 PM   #3 (permalink)
Thanks for the reply. I wasn't able to see it on bitpim, searched for any upgrades but, there weren't any
Old 02-27-2008, 06:11 PM   #4 (permalink)
Have you tried using the sdcard to move the ringtones?
Old 04-05-2008, 03:48 PM   #5 (permalink)
mijoe73 is on a distinguished road
There isn't a folder for the ringtones
mijoe73 is offline   Reply With Quote
Old 04-14-2008, 06:17 PM   #6 (permalink)
If u have a sdcard send to my sounds...then send the ringtone to urself and save it as a ringtone
Old 04-17-2008, 08:26 PM   #7 (permalink)
Raila is on a distinguished road
There are two options for getting ringtones onto our phones.
Method 1 for the more techno saavy, make sure you have the drivers all the way installed. I didnt and I had no idea they werent.
here then use Bitpim or QPST to delve into the system
Method 2 for the less tech inclined, make sure that if you are copying sounds to the phn though the "Copy to/from card" option with a Transflash card, they must be saved under the Sounds folder. Then you have to "text" them to your own number as a message and make sure you have the settings & tools/memory/save options/sounds settings set To Phone, text the sound to yourself, softkey Save As Ringtone and bingo....
new ringtone :>
Raila is offline   Reply With Quote
Old 04-17-2008, 08:37 PM   #8 (permalink)
new ringtone :>
Thanks for the information.
Old 04-17-2008, 08:51 PM   #9 (permalink)
No problem.
Its easier to have stuff in one place
How to put custom ringtones in Motorola phones DeathGrind Motorola Phones 0 07-22-2008 09:51 PM
Video ringtones on flipshot invwill Samsung FlipShot 3 05-15-2008 07:37 AM
Samsung flipshot review michigan mobile Samsung FlipShot 1 01-17-2008 08:41 PM
Ringtones on LG 8300 Help jjjordan14 LG VX8300 5 02-18-2007 08:43 AM
