Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Discontinued Samsung Phones > Samsung Glyde
Samsung Glyde Discuss Samsung Glyde u940 Here
Old 05-23-2008, 04:33 PM   #1 (permalink)
Default How to insert and remove memory card on Samsung Glyde
Inserting / removing a memory card - Samsung Glyde (SCH-u940)
The Samsung Glyde (SCH-u940) supports a microSD (TransFlash) memory card. A memory card is not included with the phone but can be purchased from any Verizon Wireless retail store or at the online store.
Inserting a memory card:
  1. Press and hold the power key (located on the upper-right side of the phone) to turn the phone off.
  2. Slide the top end of the battery cover forward then lift the bottom end to remove it.
  3. With the metal pins facing down, slide the memory card into the card slot.
  4. Carefully press the bottom end of the battery cover down then slide it up until it snaps into place.
Removing a memory card:
To avoid damage to the memory card, do not remove while storing or moving data.
  3. Carefully slide out the card to remove it.
  4. Carefully press the bottm end of the battery cover down then slide it up until it snaps into place.
How to insert / remove a memory card on Samsung Omnia admin_mvu Samsung Omnia 0 12-20-2008 10:11 PM
How to insert / remove a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:54 PM
How to insert / remove a memory card on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:45 PM
