Enabling / disabling handset restrictions - Samsung Glyde (SCH-u940)
- From the main screen, touch MENU.
- Touch Settings & Tools.
- Touch Phone Settings.
- Touch Security.
- Enter the Phone Lock Code (typically the last four digits of the phone number) then touch DONE.
- Touch Restrictions.
- Enter the Calls and Services Code (typically the last four digits of the phone number) then touch DONE.
- Touch the desired item then adjust as desired.
Location Setting
Calls
Messages
Dial-Up Modem
Location Setting
Lock Setting: Enables Location Settings password protection. Unlock Setting: Disables Location Settings password protection.
Calls
Incoming Calls
Allow All: Enables all incoming calls. Contacts Only: Enables incoming calls from contacts only. Block All: Disables all incoming calls.
Outgoing Calls
Allow All: Enables all outgoing calls. Contacts Only: Enables outgoing calls from contacts only. Block All: Disables all outgoing calls.
Messages
Incoming Messages
Allow All: Enables incoming messages. Block All: Disables incoming messages. Outgoing Messages
Allow All: Enables outgoing messages. Block All: Disables outgoing messages.
Dial-up Modem
Allow All: Enables the dial-up modem function. Block All: Disables the dial-up modem function.
