Performing a soft reset - Samsung SCH-i760
A soft reset is the most useful tool for resolving a variety of issues. In most cases, a soft reset will not affect data on the device, unless the battery is very low. Nevertheless, it is good practice to perform a sync operation before any reset to ensure that the data is backed up.
Remove / disconnect all third party devices (e.g. SD Card, headset, etc.).
- Slide open the screen to expose the QWERTY keyboard.
- With the phone in landscape orientation, use the stylus to gently press and release the reset button (located below the left soft key).
