Samsung i760 Discuss Samsung i760 Here.
Old 09-29-2008, 04:27 PM   #1 (permalink)
lasllc is on a distinguished road
Question From 700W to i760 or xv6800 ??
I need to change my phone. Absolutely needs to be WinMob 6 pro and verizon (i am grandfathered into a plan i dont dare give up).
Which phone ? These two are so close in their specs it seems that may simply be a choice how it feels. Is that a true statement ? are there any strong feeling out there as to why you made the choice ? I would certainly appreciate any guidance.
Thanks for you time and thoughts,
Roger
lasllc is offline   Reply With Quote
Old 09-29-2008, 04:33 PM   #2 (permalink)
I personally like the i760. It just feels more solid in your hand. For sure I know i760 supports Windows Mobile 6.1 (upgrade option) but not sure about XV6800, although I think it should.
Old 09-29-2008, 04:57 PM   #3 (permalink)
Thats the problem; they are basically identical units. I think the i760 has a somewhat finer resolution screen and will take a 2gig card vs the 4gig on the 6800 but beyond that ??
It may just come down to how it feels.
Roger
Old 09-30-2008, 01:27 PM   #4 (permalink)
Telephone User
darthtater1968's Avatar
darthtater1968 is on a distinguished road
There is a freeze on the 760 as of right now. Until about a week ago I had the 760 until I had problems, and much to my surprise, they were not able to replace my 760 with another, but sent me a brand new out of the box 6800.
Although I liked my 760, the 6800 does have an available 6.1 update and is also pro, you can run VZNav on it and everything else is pretty much the same. I also run a 4gb card, others have reported using 6 gb cards.
Hope that helps.
darthtater1968 is offline   Reply With Quote
Verizon XV6800 Gets Keyboard Fix michigan mobile Verizon Wireless XV6800 1 10-12-2008 04:56 PM
Samsung i760 work with Goodlink? donkeypunch Samsung i760 1 01-19-2008 07:52 PM
How do I sync lotus 6.5 to my I760 WITHOUT Outlook? richb Samsung i760 0 01-06-2008 09:36 AM
Verizon Wireless XV6800 admin_mvu Verizon Wireless XV6800 3 11-28-2007 07:25 AM
Palm Releases 1.10 Update for Verizon Treo 700w cdma Palm Treo 700w 0 04-20-2006 11:01 AM
