09-10-2009, 10:11 PM
How to use the display easy setup on Samsung Intensity
Using the display Easy Set-up - Samsung Intensity (SCH-u450)
- From the main screen, press the center of the 5-way navigation pad to choose MENU.
- Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
- Select Display Settings then press the center of the 5-way navigation pad to choose OK.
- Select Easy Set-up then press the center of the 5-way navigation pad to choose OK.
- Enter the text for the Personal Banner then press the center of the 5-way navigation pad to choose SET.
- Select the Display Backlight duration then ress the center of the 5-way navigation pad to choose SET.
- 7 seconds
- 15 seonds
- 30 seconds
- Always On
- Select the Keypad Backlight duration then press the center of the 5-way navigation pad to choose SET.
- 7 seconds
- 15 seonds
- 30 seconds
- Select the desired Wallpaper then press the center of the 5-way navigation pad to choose SET.
- Select the desired Display Theme then press the center of the 5-way navigation pad to choose SET.
- White
- My Place
- Fresh Water
- Select the desired Main Menu Type then press the center of the 5-way navigation pad to choose SET.
- Select the Dial Fonts then press the center of the 5-way navigation pad to choose SET.
- Select the Main Clock Format then press the center of the 5-way navigation pad to choose SET.
- Large Analog
- Digital 12
- Large Digital 12
- Digital 24
- Large Digital 24
- Off
