Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Intensity
Samsung Intensity Discuss Samsung Intensity Here
Old 09-10-2009, 10:15 PM   #1 (permalink)
Default How to clear temporary internet files on Samsung Intensity
Clearing temporary internet files - Samsung Intensity (SCH-u450)
  1. From the main screen, press the center of the 5-way navigation pad to choose MENU.
  2. Select Media Center then press the center of the 5-way navigation pad to choose OK.
  3. Select Mobile Web then press the center of the 5-way navigation pad to choose OK.
  4. Press the right soft key to choose Menu.
  5. Select Manage Memory then press the left soft key to choose OK.
  6. Select the desired item then press the left soft key to choose OK.
    After clearing the Cache or History the device will revert back to the browser. Cache: Visited website content stored on your device. Cache enables your browser to download only the content that has changed since you last visited a website. Since the browser only downloads changed content, pages are loaded faster. History: A listing of URLs (website addresses) that you have recently visited. Cookies: Cookies are used to store information that helps personalize your Web browsing experience. Cookies may contain information including: website preferences, login settings, shopping cart contents and more. Auto Fill: A feature that is used to automatically enter information into online forms.
  7. Press the left soft key to choose Yes.
  8. Press the left soft key to choose OK.
