Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Discontinued Samsung Phones > Samsung Intensity
Samsung Intensity Discuss Samsung Intensity Here
Old 09-10-2009, 10:19 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Default How to perform a master reset on Samsung Intensity
Performing a master reset - Samsung Intensity (SCH-u450)
This procedure will erase all user data and restore the handset to the original factory settings.
  1. From the main screen, press the center of the 5-way navigation pad to choose MENU.
  2. Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
  3. Select Phone Settings then press the center of the 5-way navigation pad to choose OK.
  4. Select Security then press the center of the 5-way navigation pad to choose OK.
  5. Enter the Security Code (default is the last 4 digits of the phone number) then press the center of the 5-way navigation pad to choose OK.
  6. Select Restore Phone then press the center of the 5-way navigation pad to choose OK.
  7. Select Yes then press the center of the 5-way navigation pad to choose OK.
  8. Press the center of the 5-way navigation pad to choose OK.
  9. Enter the Security Code (default is the last 4 digits of the phone number) then press the center of the 5-way navigation pad to choose OK.
LinkBacks (?)
LinkBack to this Thread: http://www.myvusers.com/forums/samsung-intensity/4280-how-perform-master-reset-samsung-intensity.html
Posted By For Type Date
How to Troubleshoot a Samsung Intensity | eHow.com This thread Refback 08-22-2011 07:31 AM
Samsung Intensity Reset | Download Free User Guide, Manual Guide, Owner Guide and Circuit and Wiring Diagram This thread Refback 11-18-2010 10:20 AM
