09-14-2008, 09:48 PM
How to create and send a TXT message on Samsung Knack
Creating and sending a TXT message - Samsung Knack SCH-u310
- From the main screen, press the left soft key to choose Menu.
- Select Messaging then press OK.
- Select Send Message then press OK.
- Select the desired option then press OK.
- Contacts
- Enter Number
- Recent Calls
- If using Contacts / Recent Calls, select the desired Contact / Recent Call then press the left soft key to choose Select.
If entering a number, enter the desired 10-digit mobile number(s) then press the left soft key to choose Next.
- Press the left soft key to choose Next.
- Enter the desired text message.
- If adding a graphic or sound is desired, press the right soft key to choose Options.
- Select Add then press OK.
- Select Add Graphic or Add Sound then press OK.
- Select the desired graphic or sound then press the left soft key to choose Select.
- Press the left soft key to choose Send.
