Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 12:01 PM   #1 (permalink)
Default How to enable / disable GPS location on Samsung Renown
Enabling / disabling GPS location - Samsung Renown (SCH-u810)
  1. From the main screen, press OK to choose Menu
  3. Select Phone Settings then press OK.
  4. Select Location then press OK.
  5. Select the desired setting then press OK. Location On GPS location is enabled E911 Only GPS location is disabled
How to enable / disable auto save messaging feature on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:46 PM
How to enable / disable handset restrictions on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:41 PM
How to enable / disable GPS location on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 11:58 AM
How to enable / disable GPS location on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:44 PM
How to enable / disable GPS location on Samsung FlipShot (SCH-u900) admin_mvu Samsung FlipShot 0 01-03-2008 06:01 PM
