Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 01:45 PM   #1 (permalink)
Default How to send contacts via Bluetooth on Samsung Renown
Sending Contacts via Bluetooth - Samsung Renown (SCH-u810)
The receiving device must be able to support Bluetooth Object Push and have Bluetooth enabled and visible (for Bluetooth pairing). Please refer to the documentation that accompanied the receiving device for assistance with Bluetooth.
  3. Select Bluetooth Menu then press OK.
    If the receiving device appears in the list (indicating that it has already been paired), skip to step 9.
  4. Select Add New Device then press OK.
    If prompted to Turn Bluetooth on, select Yes then press OK.
  5. When prompted with PLACE DEVICE YOU ARE CONNECTING TO IN DISCOVERABLE MODE press OK.
  6. Select the desired Bluetooth device then press OK to choose Pair.
  7. Enter the default passkey of 0000 (four zeros) then press OK.
  8. Select the desired connection option then press OK.
    • Always ask: Prompt each time before connecting.
    • Always connect: Connect automatically.
  9. Select the desired Bluetooth device then press the right soft key to choose Options.
  10. Select Send Name Card then press OK.
  11. Select the desired contact(s) then press OK to choose Mark.
  12. Press the left soft key to choose Done.
    If prompted to Connect, select Yes then press OK.
How to send contacts via Bluetooth on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:01 PM
How to send contacts via Bluetooth on LG Dare admin_mvu LG Dare 0 06-26-2008 02:46 PM
How to send contacts via Bluetooth on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:01 PM
How to send contacts via Bluetooth on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:08 AM
How to send contacts via Bluetooth on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:52 PM
