Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 01:46 PM   #1 (permalink)
Default How to enable / disable auto save messaging feature on Samsung Renown
Enabling / disabling the Auto Save messaging feature - Samsung Renown (SCH-u810)
  1. From the main screen, press the left soft key to choose Message.
  2. Press the left soft key to choose Settings.
  3. Select Auto Save Sent then press OK.
  4. Select the desired setting then press OK: On Enable the auto save feature Off Disable the auto save feature Prompt Ask to save the message
How to enable / disable auto save messaging feature on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:14 PM
How to enable / disable the auto save messaging feature on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 12:02 PM
How to enable / disable the auto save message feature on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:48 PM
How to enable / disable auto save message feature on Samsung Gleam (SCH-u700) admin_mvu Samsung Gleam 0 01-03-2008 05:51 PM
How to enable / disable the auto save messaging feature on Samsung SCH-a930 admin_mvu Samsung a930 0 12-21-2007 04:03 PM
