11-22-2008, 01:51 PM
How to create and send a TXT message on Samsung Renown
Creating and sending a TXT message - Samsung Renown (SCH-u810)
- Select New Message then press OK.
- Select TXT Message then press OK.
- Enter the desired 10-digit mobile number(s) or email address(s) in the To: fields(s) then press OK.
- Enter the desired text message.
- To add a graphic, animation or sound, press the right soft key to choose Options.
- Select Add then press OK.
- Select the desired category (Graphic, Animation or Sound) then press OK.
- Select the desired item then press OK.
- Press OK to choose Send.
