Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 01:54 PM   #1 (permalink)
Default How to insert / remove a memory card on Samsung Renown
Inserting / removing a memory card - Samsung Renown (SCH-u810)
The Samsung SCH-u810 supports a microSD (TransFlash) memory card.
  1. Remove the battery cover.
Insert memory card
Remove memory card
Insert memory card
  1. With the label up, insert the memory card then press in to lock into place.
  2. Re-insert the battery cover.
Remove memory card
To avoid damage to the memory card, do not remove while storing or moving data.
  1. Press in on the card to unlock it, then slide the card out.
  2. Replace the battery cover.
How to insert / remove a memory card on Samsung Omnia admin_mvu Samsung Omnia 0 12-20-2008 10:11 PM
How to insert / remove a memory card on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:45 PM
How to insert and remove memory card on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:33 PM
