Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 07:45 PM   #1 (permalink)
Default How to format a memory card on Samsung Renown
Formatting a memory card - Samsung Renown (SCH-u810)
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
  2. Select Settings & Tools.
  3. Select Memory then press OK.
  4. Select Card Memory then press OK.
  5. Press the right soft key to choose Options then press OK to choose Format Card.
  6. Select Yes then press OK.
How to insert / remove a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:54 PM
How to format a memory card on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 07:58 PM
How to format a memory card on Samsung u740 admin_mvu Samsung Alias 2 08-07-2008 08:37 PM
How to format a memory card on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:34 PM
