Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Renown
Samsung Renown Discuss Samsung Renown Here
Old 11-22-2008, 07:53 PM   #1 (permalink)
Default How to assign In Case of Emergency (ICE) contacts on Samsung Renown
Assigning In Case of Emergency (ICE) contacts - Samsung Renown (SCH-u810)
  1. From the main screen, press the right soft key to choose Contacts.
  2. Ensure that In Case of Emergency is selected then press OK to choose View.
  3. Select Contact 1, 2 or 3 then press OK to choose Add.
    To reassign an existing ICE contact, select the current contact, press the right soft key to choose Options, select Re-assign then press OK.
  4. Select From Contacts or New Contact then press OK.
    • From Contacts: Select a contact then press OK.
    • New Contact: Enter a Name and Number to create a new contact then press OK to choose Save.
admin_mvu is online now   Reply With Quote
How to send contacts via Bluetooth on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:45 PM
How to enable / disable handset restrictions on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:41 PM
How to send contacts via Bluetooth on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:01 PM
How to assign In Case of Emergency (ICE) keys on Samsung Knack admin_mvu Samsung Knack 0 09-14-2008 09:47 PM
Contacts copier (from Samsung) newtoverizon_sb Ask the Tech? 2 02-18-2008 04:40 PM
