Go Back   My Verizon Users > Verizon Phones > Smartphones > Samsung Saga
Old 11-16-2008, 07:42 PM   #1 (permalink)
Default How to enable / disable / modify the SIM PIN on Samsung Saga
Enabling / disabling / modifying the SIM PIN - Samsung Saga
Enabling the Subscriber Identity Module (SIM) Personal Identification Number (PIN) locks the SIM card so that it cannot be used until the correct code is entered. If the incorrect PIN code is entered too many times, a PIN Unlock Key (PUK) must be obtained from Verizon Wireless. Ensure a SIM card is properly inserted and the Network mode is set to International GSM mode.
  1. From the Today screen, tap Start > Phone.
  2. Tap Menu > Options.
  3. Tap Security. (located at the bottom of the screen).
Enabling / disabling the SIM PIN
  1. Ensure Require PIN when phone is used is checked / unchecked.
  2. Enter the current PIN code then tap Enter.
    The default PIN code is 1111.
Modifying the SIM PIN
EnsureRequire PIN when phone is used is checked.
  1. Tap Change PIN.
  3. Enter the new PIN code (4 to 8 digits) then tap Enter.
  4. Re-enter the new PIN code then tap Enter.
  5. Tap ok.
How to enable / disable Wi-Fi on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:51 PM
How to enable / disable Bluetooth discovery mode on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:50 PM
How to enable / disable the auto signature on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:52 PM
How to enable / disable the auto save message feature on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:48 PM
