Go Back   My Verizon Users > Verizon Phones > Smartphones > Samsung Saga
Old 11-16-2008, 07:45 PM   #1 (permalink)
Default How to insert / remove a memory card on Samsung Saga
Inserting / removing a memory card - Samsung Saga
The Samsung Saga supports up to 16GB microSD (TransFlash) memory card.
Inserting a memory card:
  1. Press and hold the Power button then tap OK on the screento turn the phone off.
  2. Press down the lower end of the battery cover then slide it out.
  3. With the metal pins facing up, slide the memory card into the card slot.
  4. Slide the battery cover up until it snaps into place.
Removing a memory card:
To avoid damage to the memory card, do not remove while storing or moving data.
  3. Press in on the card then slide it out.
How to insert / remove a memory card on Samsung Omnia admin_mvu Samsung Omnia 0 12-20-2008 10:11 PM
How to insert / remove a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:54 PM
How to insert and remove memory card on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:33 PM
