Go Back   My Verizon Users > Verizon Phones > Smartphones > Samsung Saga
Old 11-16-2008, 07:51 PM   #1 (permalink)
Default How to unblock the SIM PIN on Samsung Saga
Unblocking the SIM PIN - Samsung Saga
The PIN Unlock Key (PUK) can be used to reset a blocked SIM card and must be obtained from Verizon Wireless before proceeding.
  1. From the Today screen, tap the PIN lock icon (located at the top of the screen).
  2. Tap Enter PIN.
  3. Enter the 8-digit PUK obtained from Verizon Wireless then tap Enter.
    If an invalid PUK is entered too many times, the SIM card will be permanently disabled.
  4. Enter the new PIN code (4 to 8 digits) then tap Enter.
  5. Re-enter the new PIN code then tap Enter.
  6. Tap ok.
How to Configure Wi-Fi on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:46 PM
How to insert / remove a memory card on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:45 PM
How to create a tethered modem connection on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:41 PM
Samsung Saga Specification admin_mvu Samsung Saga 4 11-16-2008 07:35 PM
