Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Sway
Samsung Sway Discuss Samsung Sway Here
Old 11-16-2008, 08:01 PM   #1 (permalink)
Default How to send contacts via Bluetooth on Samsung Sway
Sending contacts via Bluetooth - Samsung Sway (SCH-u650)
The receiving device must support Bluetooth Object Push, have Bluetooth enabled and be made visible (for Bluetooth pairing). Please refer to the documentation that accompanied the receiving device for assistance with Bluetooth.
  3. Select Bluetooth Menu then press OK.
    If the receiving device appears in the list (indicating that it has already been paired), skip to step 9.
  4. Select Add New Device then press OK.
    If prompted to turn Bluetooth power on, select Yes then press OK.
  5. Press OK.
  6. Select the desired Bluetooth device then press OK to choose PAIR.
  7. Enter the passkey then press OK.
    The default passkey is 0000 (4 zeroes).
  8. Select the desired connection option then press OK.
    • Always ask: Prompt each time before connecting.
    • Always connect: Connect automatically.
  9. Select the desired Bluetooth device then press the right soft key to choose Options.
  10. Select Send Name Card then press OK.
  11. Select the desired contact(s) then press OK to choose MARK.
    Up to 10 contacts can be selected.
  12. Press the left soft key to choose Done.
How to send contacts via Bluetooth on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:45 PM
How to send contacts via Bluetooth on LG Dare admin_mvu LG Dare 0 06-26-2008 02:46 PM
How to send contacts via Bluetooth on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:01 PM
How to send contacts via Bluetooth on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:08 AM
How to send contacts via Bluetooth on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:52 PM
