11-16-2008, 08:07 PM
How to create and send a TXT message on Samsung Sway
Creating and sending a TXT message - Samsung Sway (SCH-u650)
- Select New Message then press OK.
- Select TXT Message then press OK.
- Enter the 10-digit mobile number or email address in the To:.
- Enter the text message.
- To add graphics, animations or sounds, press the right soft key to choose Options.
- Select Add then press OK.
- Select the desired category (Graphics, Animations or Sounds) then press OK.
- Select the desired location then press OK.
- Select the desired object then press OK.
- Press OK to Send the message.
