Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Sway
Samsung Sway Discuss Samsung Sway Here
Old 11-16-2008, 08:08 PM   #1 (permalink)
Default How to create and send a PIX message on Samsung Sway
Creating and sending a PIX message - Samsung Sway (SCH-u650)
  1. From the main screen, press the Camera key (located on the lower-right side of the handset).
  2. Press OK to TAKE the picture.
  3. Press OK to choose SEND.
  4. Enter the 10-digit mobile number or email address in the To: field then press OK.
  5. Add Text to the message if desired.
  6. Add a Sound to the message if desired.
    1. Select the Sound field then press the left soft key to choose Sounds.
    2. Select the desired sound then press OK.
  7. Add a Subject to the message if desired.
  8. Add a Name Card if desired.
    1. Select the Name Card field then press the left soft key to choose Add.
    2. Select the desired option then press OK.
      If selecting contacts, select the desired contact then press OK twice.
    3. Repeat as needed to add additional contacts.
  9. Press OK to SEND the message.
How to create and send a TXT message on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:51 PM
How to create and send a FLIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:12 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:07 PM
How to create and send a TXT message on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 12:02 PM
How to create and send a TXT message on Samsung Knack admin_mvu Samsung Knack 0 09-14-2008 09:48 PM
