11-16-2008, 08:14 PM
How to enable / disable auto save messaging feature on Samsung Sway
Enabling / disabling the Auto Save messaging feature - Samsung Sway (SCH-u650)
- Select Auto Save Sent then press OK.
- Select the desired setting then press OK. On Enables the auto save feature. Off Disables the auto save feature. Prompt Handset will prompt to save the message.
