Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Sway
Samsung Sway Discuss Samsung Sway Here
Old 11-16-2008, 09:15 PM   #1 (permalink)
Default How to enable / disable auto signature on Samsung Sway
Enabling / disabling the auto signature - Samsung Sway (SCH-u650)
  1. From the main screen, press the left soft key to choose Message.
  2. Press the left soft key to choose Settings.
  3. Select Signature then press OK.
  4. Select the desired setting then press OK. None Disables the auto signature. Custom Enables the auto signature.
    Enter the desired signature then press OK.
How to enable / disable auto save messaging feature on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:14 PM
How to enable / disable auto signature on LG Dare admin_mvu LG Dare 0 06-26-2008 03:57 PM
How to enable / disable auto signature on LG enV2 admin_mvu LG enV2 0 06-05-2008 12:08 PM
How to enable / disable the auto signature on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 05:52 PM
How to enable / disable auto signature feature on LG enV (VX9900) admin_mvu LG enV 0 01-03-2008 06:44 PM
