Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Discontinued Samsung Phones > Samsung u430
Samsung u430 Discuss Samsung u430 Here
Old 10-03-2008, 11:57 AM   #1 (permalink)
Default How to create and send a PIX message on Samsung u430
Creating and sending a PIX message - Samsung SCH-u430
  1. From the main screen, press the Camera key (located on the right side of the handset).
  2. Take aim then press OK to Take the picture.
  3. Press OK to choose Send.
  4. Enter the 10-digit mobile number or email address then press OK.
  5. Add Text to the message if desired.
  6. Add a Sound to the message if desired.
    1. Select the Sound field.
    2. Press the left soft key to choose Sounds.
    3. Select the desired sound then press OK.
  7. Add a Subject to the subject field if desired.
  8. Press OK to choose Send.
How to create and send a TXT message on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:51 PM
How to create and send a FLIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:12 PM
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:07 PM
How to create and send a TXT message on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 12:02 PM
