Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung u430
Samsung u430 Discuss Samsung u430 Here
Old 10-03-2008, 11:58 AM   #1 (permalink)
Default How to enable / disable GPS location on Samsung u430
Enabling / disabling GPS location - Samsung SCH-u430
  1. From the main screen, press OK to choose Menu
  3. Select Phone Settings then press OK.
  4. Select Location then press OK.
  5. Select the desired setting then press OK. Location On GPS location is enabled. E911 Only GPS location is disabled.
How to enable / disable GPS location on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 12:01 PM
How to enable / disable GPS location on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to enable / disable handset restriction on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 11:56 AM
How to enable / disable GPS location on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:44 PM
How to enable / disable GPS location on Samsung FlipShot (SCH-u900) admin_mvu Samsung FlipShot 0 01-03-2008 06:01 PM
