10-03-2008, 12:02 PM
How to enable / disable the auto save messaging feature on Samsung u430
Enabling / disabling the Auto Save messaging feature - Samsung SCH-u430
- Select Auto Save Sent then press OK.
- Select the desired setting then press OK: On Enable the auto save feature Off Disable the auto save feature Prompt Ask to save the message
