Parse error: syntax error, unexpected T_STRING in /home/mvu/public_html/forums/global.php(607) : eval()'d code on line 1240
Manage Contacts - Sharp KIN TWO - My Verizon Users
Sharp KIN TWO Discuss Sharp KIN TWO Here
Old 05-20-2010, 10:28 AM   #1
admin_mvu
Default Manage Contacts - Sharp KIN TWO
  1. From the Home screen, swipe right.
  2. Select Contacts.
  3. Select an option.
    Adding a contact
    Deleting a contact
    Editing a contact
    Adding a pause
Adding a contact
Swipe left to view contacts by accounts.
  1. Select New.
  2. Select choose photo.
  3. Select a photo.
    Swipe right to capture a photo.
  4. Drag & Stretch the image (if desired) then select Done (located in the upper-right).
  5. Enter the First name / Last name.
  6. Select Ringtone.
  7. Select a ringtone.
  8. Enter the phone number.
  9. Select the appropriate field to enter additional contact information.
    • Add phone
    • Add email
    • Add IM (Instant Messenger)
    • Add address
    • Birthday
    • Anniversary
    • Web site
    • Details
      • Prefix
      • Middle
      • Suffix
    • Work
      • Job title
      • Department
      • Company
      • Notes
  10. Select Save (located in the upper-right).
Deleting a contact
  1. Select the contact.
  2. Select More (located in the upper-right).
  3. Select Delete.
  4. Select delete.
Editing a contact
  2. Select Edit (located in the upper-right).
  3. Edit the contact information then select Save (located in the upper-right).
    • Choose photo
    • First name
    • Last name
    • Add phone
    • Add email
    • Add address
    • Birthday
    • Anniversary
    • Web site
    • Details
      • Prefix
      • Middle
      • Suffix
    • Work
      • Job title
      • Department
      • Company
      • Notes
Adding a pause
  3. Select the number.
  4. Add comma(s) as required then select Save (located in the upper-right).
    Repeat as desired. , (comma) Inserts a 2-second pause between the number dialed and the additional numbers. Each additional , (comma) will add 2-seconds to the pause.
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
