UTStarcom XV6700 Discuss UTStarcom XV6700 Here.
Old 11-08-2006, 10:30 AM   #1 (permalink)
ClwTL will become famous soon enough
Default Audiovox vx6700 tips
some tips for the 6700
ClwTL is offline   Reply With Quote
Old 11-08-2006, 10:31 AM   #2 (permalink)
Default Message Sent Notification
If you're tired of the "Message Sent" notification after sending an SMS/text message, you can disable them: Make sure you add a DWORD Value
HKLM\Software\Microsoft\Inbox\Settings\SMSNoSentMs g = 1 (DWORD decimal)
And to re-enable:
HKLM\Software\Microsoft\Inbox\Settings\SMSNoSentMs g = 0 (DWORD decimal)
Please note that the 'Settings' key may not exist in your device, and thus may have to be created first.
Old 11-08-2006, 10:32 AM   #3 (permalink)
Default Enable dial-up networking
Enabling Dial Up Networking
1. Go to the PHONE application
2. typed in ##3328873
3. then hit send
4. screen pops up with a Please Enter Unlock Code and a white box
5. enter code 000000
6. new window pops up Named "ESPT"
7. There are two options that read diabled Enable WModem and BT DUN
8. Highlight the the first item then click edit on the bottom
9 Choose enable
10 Hlight the the second item BT DUN then click edit on the bottom
11. Choose enable
7. Push Save / OK
8. Push Ok
9. follow the prompt to restart your device
after your VX7600 restarts launch "My Bluetooth Places" on your laptop
then turn on blue tooth on your vx6700 by clicking Start / Settings / Connetions / Bluetooth/ check off Turn on Blue tooth and make my device discoverable
Old 11-08-2006, 10:33 AM   #4 (permalink)
Default Enable WIFI & Phone to work at same time
OK!!! heres the problem.
A lot of us want to be able to use phone and evdo at the same time.
1) Download PHM Regedit (search google for "phm regedit download")
2) start phm regedit go to HKEY LOCAL MACHINE>SERVICES>WirelessMGR
3) Edit the key called mutexflag change the value from 1 to 0
4) accept the changes close the program set you phone down and WAIT 15 minutes.
5) reset phone by pushing the reset button on the bottom
Now you can turn wifi and phone on at same time
Now for what you do to solve your problem with connecting on accident to EVDO
1) go to START>Setting>Connections>Connections>Manage Existing Connections>
2) push and hold on top of data network until the option delete pops up
3) delete it NO MORE EVDO
Old 11-08-2006, 10:34 AM   #5 (permalink)
Default Using Voice Command to open specific websites
I was wanting to use Voice Command to open a specific web site. For example I wanted to say "Open Weather" and it would go straight to my local forecast on www.weather.com.
To do it I:
1. Opened internet explorer, found my local forecast and saved it as a favorite.
2. Opened Windows Explorer and copied the internet shortcut I had created from the Windows\Favorites folder and pasted it in the Windows\Start Menu\Programs folder.
3. I renamed the shortcut to "Weather"
I can now use Voice Command to go directly to my forecast. Obiously this could be done with any website I visit on a regular basis (like ORB). I suppose if I create enough my programs folder will look pretty full, but with Voice Command I don't really care so much.
Old 11-08-2006, 10:38 AM   #6 (permalink)
Default VX6700 MP3 Ringtone From SD Card How-To
This is going to be a work in progress. By doing the below steps you take responsibility of damaging your phone in to your own hands and will not hold me or anyone else liable. I have successfully done this on my phone but have not had enough time to experiment thoroughly.
Requirements:
- SD Card Preloaded With MP3
- Windows Mobile/Pocket PC Registry Editor (Google "PHM RegEdit Download")
Steps:
1) Locate the full path of the ring tone you want to use on your SD card. You can do this either via your PC through ActiveSync Explore or via the Windows Mobile File Explorer. An example path would be "\Storage Card\My Music\File Name.mp3".
2) Launch your registry editor on the VX6700.
3) Navigate to "HKEY_CURRENT_USER\ControlPanel\Sounds"
4) From here you can choose what event you want to assign an MP3 to by selecting the next branch in the registry. An example is the "RingTone0" folder. This is for the standard incoming call ring tone.
5) Assuming you chose RingTone0, you will then need to create or modify a String Value (Edit > New String Value to create) with a value name of "Sound". So the full path would be "HKEY_CURRENT_USER\ControlPanel\Sounds\RingTone0\S o und" in our example.
6) Set the Value Data for the "Sound" to the full path you chose in Step 1. In this example it would be "\Storage Card\My Music\File Name.mp3" (without quotes).
7) Hit the OK button and hit Yes to any prompts to save this change.
Thats it. The change should take immediately with no reboot required. I have noticed if you go into your Phone > Options screen it may not let you out again unless you choose a ring tone located in your phone itself, so avoid that at all cost.
Old 03-20-2007, 02:56 AM   #7 (permalink)
khanhhq is on a distinguished road
Default Using VX6700 in other network.
Hi Every One, i am new comer for this Forum. I would like to buy one VX6700 from Verizon network to use it in the other CDMA network, any one can help me to how to unlock this phone when buy from Verizon and procedure to unlock it.
Thank you so much.
PS: You can contact with me on khanhetc@yahoo.com
khanhhq is offline   Reply With Quote
Already found some great tips here!! nickg LG Dare 1 10-01-2008 07:21 PM
Other Motorola Q9m Tips and Tricks admin_mvu Motorola Q9m 0 12-25-2007 08:30 PM
Motorola Q9m E-mail Tips admin_mvu Motorola Q9m 0 12-25-2007 08:28 PM
Voice Mail Quick Tips admin_mvu Tips & Tricks 1 02-28-2007 11:00 AM
What's the deal with Audiovox / Pantech / Verizon / UTStarcom / Nokia brand? admin_mvu Verizon Wireless Phones 0 02-22-2007 10:56 AM
