08-25-2008, 09:30 AM
How to enable / disable auto signature feature on Blitz
Enabling / disabling auto signature - Verizon Wireless Blitz
- Select Signature then press the centerof the 5-way navigation pad to choose OK.
- Select the desired setting then press the center of the 5-way navigation pad to choose OK:
None Select to disable the auto signature. Custom Select Custom, press the center of the 5-way navigation pad then enter a desired signature.
