Creating a Bluetooth paired connection - Verizon Wireless Blitz
The receiving device must be able to support Bluetooth Object Push, have Bluetooth enabled and visible (for Bluetooth pairing). Please refer to the documentation that accompanied the receiving device for assistance with Bluetooth.
- From the main screen, press OK to choose Menu.
- From Settings & Tools, select Bluetooth Menu then press the center of the 5-way navigation pad to choose OK.
- Select Add New Device then press the center of the 5-way navigation pad to choose OK.
If prompted to turn Bluetooth on, press press the center of the 5-way navigation pad to choose Yes.
- Select the desired Bluetooth device then press press the center of the 5-way navigation pad to choose Pair.
- Enter the default passkey of 0000 (four zeros) then press press the center of the 5-way navigation pad to choose OK.
- Select the desired connection option then press the center of the 5-way navigation pad to choose OK.
- Always ask: Prompt each time before connecting.
- Always connect: Connect automatically.
