Wireless PC Cards Discuss Wireless PC Cards here
Old 09-07-2006, 05:20 PM   #1 (permalink)
Default Kyocera KPC650
The KPC650 card utilizes our VZAccess manager which serves as a focal point for all of your internet connection needs. Using BroadbandAccess the KPC650 operates with typical download speeds of 400-700 kbps and bursts up to 2.0 Mbps. It also features an adjustable antenna which can be angled for optimized reception.
Basic Information
Size: 2.13H x 4.84W x 0.51D inches
Weight: 2.01 oz
Basic Features
  • BroadbandAccess high-speed wireless data access of up to 2.0 Mbps
  • VZAccess Manager software for easy connection management
  • Hinged Antenna
  • BroadbandAccess and NationalAccess compatible
  • Dual-band receive diversity for better network performance
  • SMS capable
  • 32-bit CardBus interface(3.3V) for lower power consumption
  • LED indicator for service availability and data transfer status
  • Quick2Net compatible
  • Meets FCC SAR limit. Manufacturer's highest FCC reported SAR: 1.17. Actual SAR may vary.
Kyocera Section Deactivated admin_mvu Announcements 0 01-25-2008 04:03 PM
